10R80 Noise when cold - anyone else with this "issue"?
unixadm
Elk Grove, CA
2021 F150 XLT 5.0L Sport
I just picked up a used 2021 F150 5.0L and it's currently sitting at 6,240 miles. This 4th 10Rxx I've had, and the 5th 10 speed (I had a 17 Camaro ZL1 auto). I am well aware of the whine at idle and the quirks of this transmission family. I currently have a 2024 Ranger Raptor as well, so I have a relative comparison. I also had a 2021 F150 Powerboost for over three years. On this truck I just bought, during the first 5-7 minutes of driving, I can hear a pretty loud growling noise that changes with RPM coming from what I believe is the transmission. I had the radio and HVAC off. Once the truck warms up, the noise goes away. Has anyone had this issue and if so, did you live with it, or did Ford work to address it?
The truck is still under the original powertrain warranty, it's also CPO, and I bought a PremiumCare ESP warranty for it, so I'm well covered. The interesting thing is I don't recall hearing the noise yesterday morning and the ambient conditions were pretty much identical. I had the truck backed into the driveway on Friday night just like I did last night, but today it was quite loud. I did do a long 200ish mile drive yesterday though, but I'll monitor for the next few cold starts and see if it continues.
Boen
andy
washington st
22 F-150 Platinum
They are known for the bearing going bad on the pump gear
unixadm
Elk Grove, CA
Interesting. Today when I started it up and went for a drive just like yesterday, the noise was about 90%+ less. I'll keep monitoring and will update if I learn anything further.
Porpoise Hork
Bret
IT Sys Admin
Some of them do seem to make more nose than others. Almost like a supercharger whine and from what I remember it was due to how the pump gears were cut.
unixadm
Elk Grove, CA
The noise I was hearing was not a whine or the typical whine due to Ford's straight cut pump gears. I know that noise. This was a growling noise that was easily audible inside of the cabin.
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
More likely E-IWE, is this a XL, XLT, Lariat plow prep or Tremor?
Gros Ventre
Western Wyoming
I had a noise when around 15ºF and below. Turned out to be the transmission fluid was a bit low. The noise would clear as warmup occurred.
ApolloChurchill
San Antonio
F-150 Tremor
Just sounds like fluid is a little low. It’s basically pump cavitation until the fluid expands at temp. In my experience anyways
unixadm
Elk Grove, CA
Good callout about the fluid level. Thanks
