24stx87
I have a 2024 with the 2.7. I always was annoyed by the transmission in that it seems to shift into the next gear way too early and having the lugging feeling. I assume this is to maximize fuel economy and keeping the rpm’s as low as humanly possible.
I’ve been locking out gears 8,9 and 10 around town and on the highway I reopen 8,9,10 as needed. Alternatively I drive in tow mode, but it makes the steering and downshifting a bit odd. Overall this has solved the issue 95% of the time.
It seems that locking out gears 8,9 and 10 works best to keep the intended ride quality of the truck intact, but it’s a little annoying in certain parts of town when I’m driving between 35 and 45 mph because it’s going into 7th gear at like 35 mph and giving a little of the lugging feeling. Pretty annoying to constantly lock out and unlock gear 7 when driving around town. Oddly enough sometimes it is fine in 7th gear at 35-39 mph, sometimes it feels like 6th is the gear it should be in. I assume this may have to do with any hills and maybe even if my a/c is on and working hard adding some extra strain.
now onto my actual question after that longwinded intro: will the transmission “learn” I don’t want the truck in 7th gear under let’s say 39mph if I press the gas and make it downshift every time it does it? Usually when I feel the lugging , I kinda just ride it out and not press down the throttle more. It stays in 7th gear and doesn’t downshift. So will it “learn” that when I give it a little gas, instead of just staying in gear, it’ll start to downshift itself sooner?
