Which connector to disable auto s/s on 24?
mattri
Matt
IA
24 xl
On my 19 f150 you could unplug a trailer wiring connector under the dash to disable auto s/s, can you do this on the 24s and which connector is it? Could be my old memory but looked under dash today and it seems different than the 19.
Thanks, Matt.
Nightshade
AJ
Alberta, Canada
You can’t in the 21+ without throwing an error. For 2021-2023, you can disable via FORScan.
For 2024, will have to get one like below or similar. You can’t disable AS/S on 24s without also disabling the BMS. It’s really easy to install and forget.
https://www.4dtech.com/f150-21-25-start-stop-eliminator/
mattri
Matt
IA
24 xl
Good to know, thanks.
Larrymoe
2024 F150 XL RCSB
Nightshade
AJ
Alberta, Canada
Do these sort of devices do anything to the warranty?
No they don’t, they’re straight plug and play—disables that obnoxious AS/S. You can always remove it at any time if you wish!
Larrymoe
2024 F150 XL RCSB
Upon reading the site you linked, I see that say that a couple times on there. Thank you.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Dale B
Dale
Georgia
F150(on order), SL500, S430, Boxster, 930, CJ5
Thanks, I just ordered one. It’s just what I’ve been looking for.
Update: I got it in about three days. It took no more than three minutes to install and it works perfectly. It has my recommendation.
Sojourner
Maryland
2023 F-150 Tremor
Retired Army / Disabled Vet
I plug a led nightlight into the 110v socket at the rear of the console. The low load on the inverter prevents the ASS feature from engaging.
andy18_00
Andrew
Southeast Missouri
2024 F150 XLT BAP
Accountant
I added the 4D to my truck. It works great. Would highly recommend
