Volt+Amp Meter wish
alfsauve
Alfred
Georgia USA
2023 F-150 XLT
Had the BMS go into hibernation or sleep or whatever. Cut off all auxiliary services. So I learned how to reset that (It's in the manual, btw), Face the Blue City, close your eyes and click the heels of your Blue slippers together 5 times. Every thing seems to work well for several weeks now. Just think it got confused.
BUT
Why isn't battery Voltage and charge/draw Amperage available on the upper 4 meters? It is available via diagnostic tools I understand
(2024 F-150 XLT FX4 Off Road - not using auto-start/stop)
HEY FORD. Really would like that especially since the so much of the operation of the truck is dependent on the battery and hence the BMS. Graphics-wise it could be one meter with a "needle" showing voltage and a sliding circular scale showing charge/draw.
Questions:
I've seen some reference to external, maybe app based, Volt meters. What are you using? Has anyone tapped across the BMS shunt and connected their own meter?
This will be the third winter (N. GA) so time for battery replacement. Not Ford. I lean toward Duracell probably from Batteries+. Recommendations?
I've seen some reference to an auxiliary 12V battery in some trucks. ???
Buyer2021
central TX
retired!
alfsauve
Alfred
Georgia USA
2023 F-150 XLT
Thanks Buyer 2021. I don't want to appear tech-stupid, but when you do a search you get so many results it's hard find the answers you're looking for.
Am working my way through Porposie Hork's academic paper
gagliano7
Joe
Monroe NY
I bought a plug in adapter that shows voltage at all times on amazon. It works great and it was only about 15 bucks.
gagliano7
Joe
Monroe NY
Here it is.
Ford F-150 Volt+Amp Meter wish IMG_0806
tsigwing
DFW
2025 F150 PB
How about one of these? You can see what is going on while charging and at any time it is parked. I have one on each of my vehicles.
alfsauve
Alfred
Georgia USA
2023 F-150 XLT
Appreciate the references/links.
Not thrilled with plug in VMs.
Not sure how some of these products measure current by just taping across Positive-Negative.
A lot of "hang" on meters out there.
Baring some upgrade by Ford soon, I'll DIY. Volt Meter LED modules in multiple colors are 8 for $10.
Toying with the OBD module/app for Christmas. Useful on other cars as well.
Tired Lizard
Gene
23 Maverick, 22 Escape PHEV
A lot of "hang" on meters out there..
OBDII adapter and an app to see what the truck shows for voltage and amps.
The battery monitors like Quicklynks BM2 don’t measure amps.
I use the Quicklynks BM2 and Multi-Batt Mon app to watch voltages.
Ford F-150 Volt+Amp Meter wish 1760122751286-2
Ford F-150 Volt+Amp Meter wish 1760122874155-g4
Bluegrass
PA.
2018 5L Supercrew
Current meters are not very useful unless all you want is to see something to satisfy yourself.
Voltage level is more useful if you know what the level is telling you about system performance.
The voltage you see from the Body Control Module out of a jack on the dash is lower than at the Battery terminals by a few tenths due to the loses through that module.
And it shuts off after engine shut down and the BMC times out.
Good luck.
alfsauve
Alfred
Georgia USA
2023 F-150 XLT
Thanks, Bluegrass. I like to monitoring charge/discharge rates. Think that would tell me a lot, too.
I'm ordering the OBDLink and we'll see what I learn from that.
