Eighthtry
Ok, I could not find a post on this, so hear goes. Piss on it if you can. It is nothing but an idea that I am thinking about.
My grandfather had a friend who was an old WWII pilot. He wired up a homemade panel in his 50 Ford. It had 6 or 8 on/off throw switches. He did not use a key to start the car. He simply made sure those switches were in the correct on/off position to start.
I don't recall the auxilary switch panel being an option for my F150. But I think there are threads talking about retrofitting them into F150's from the 250s and up.
I have thought about one for my 2021 F150, just not in depth yet. It is security/theft based on interrupting the starter and/or fuel pump wires.
It would use the auxillary switch panel that I think is an option available on F250 and up. I think there are threads that address installation into an F150 in this forum. But let's say there are four switches. You run a starter and/or fuel pump interrupt wire to go through each of those switches in series. The first switch is on. The second switch is off. The third switch is off, the fourth switch is on.
To start, each has to be in the assigned on/off position above. One has to know the "switch code" in order to get it started. This illustration is left to right, on, off, off, on. It starts. Any other configuration it is dead.
I am out of brain cells to burn. Will something like that work???? Can you use both starter and fuel pump through the same switch? Maybe need relays to make it work with both?
Any thoughts?
Any thoughts?
