Thud sound from the rear of the truck after accelerating... is this normal(see video)?
kayaker2637
STL
2023 XLT
2023 stock xlt 16k miles. Just had the truck in for an oil change and tire rotation at 15k, I don't think that matters but after leaving the dealer I noticed a thud when accelerating. I'm pretty observant and I know it did not happen before the dealer.
The thud doesn't happen every time but when it does happen, it's usually after coming to a stop and then about .5- 1 sec after taking off. I'd say once every 10 stops I hear it. It's kind of driving me crazy hearing it.
At first, I thought the suspension could be bind from being lifted off the ground, a weird transmission shift, or maybe gas in the tank, but it sounds more like a thump and not a slosh.
Today I crawled under the truck and was pushing things around, When I hand turn my driveshaft, it makes what I think is the sound. Is this normal or should them be some type of lube to quite it? Thanks.
Thanks for any help, this is my first Ford so I'm a little nervous about any odd sounds I get.
astro_fusion
IE, CA United States
2022 F-150 supercab, 1990 Bronco II
It's the slip yoke on the end that goes into the transmission, most come delivered pretty dry. Unbolt the driveline, clean out the spines and re lube.
ak49rzrs
Ryan
Alaska
'24 F-150 501A,w/FX4, '18 SHO, '15 F-350 CC/LB 6.7
Liquified fossil recovery
As @astro_fusion stated, that seems to be the most common cause for what you have going on. Most of the people recommend using the Super Lube with PTFE.
Ford F-150 Thud sound from the rear of the truck after accelerating... is this normal(see video)? 1750100906670-ei
Billflangjr
Tampa Florida
2024 Tremor
Your right on the money with your video ! Be sure to use PTFE Grease ! Super Lube PTFE works Great !!
