Tailgate unlatches but won’t open
DWeber319
DFW
2021 F150, 502A, PB, 6.5' Bed, Ranch Topper
2021 Lariat powerboost 48k miles
from either the fob, button, or button in the cab the tailgate will unlatch and drop a very small amount but won’t lower. There is resistance when you pull on the the tailgate. It will latch back shut by pushing on it.
I’ve had a roll up cover on for ~25k miles and it never encountered issues before.
Any and all input would be greatly appreciated
Davexxxx
MO
Temp change, or out of adjustment?
Once I put the cover on mine, it never dropped on its own again.
Doesn't bother me. I figure it is indicative of a good seal.
DWeber319
DWeber319
DFW
Maybe. I’ll look more closely it’s not impacting. I am in Texas and it is damn hot here now. But wouldn’t pulling on it bring it past the contact and then it would drop?
DWeber319
DWeber319
DFW
Davexxxx
MO
I don't know how to post a vid but once mine is clear of the cover, it drops as it should.
It requires pulling it a touch but ... Like a half inch or so.
DWeber319
DWeber319
DFW
Mine does not. Just goes springs back up. Like pulling on a spring
Davexxxx
MO
Might be something in your damping system but I'd look for an obstruction at the bottom of the tailgate. A twig, a forgotten tool, something like that., that found its way into a place causing conflict.
Jus Cruisin
Tim
Metro Detroit
Very retired
If you have autoclose maybe something is malfunctioning with that system. Worth a trip to the dealership.
DWeber319
DWeber319
DFW
Maybe. It’s almost like the solenoid that opens the latch works. But the motor that lowers it never engages.
I took the cover panel off to look inside and the latches are opening and closing just fine. It feels like a stuck motor when you pull on it
DWeber319
DWeber319
DFW
I tired the "pull harder and see what happens" method and now the tailgate lowers as it should. But the auto up doesn't work. When you hit the button the lights flash and nothing happens. So. Progress?
simonf150
Simon
MIami
2021 F150 Lariat
Exact same problem with my 2021 Lariat. The week after the 3 year warranty expired.
Am afraid to pull it harder in case i break something.
Did you ever get this resolved?
Ruffiano99
Joe
NY
2021 f150
Any update on this? Just happened to mine too.
