System off to save battery
Spiffy
Usa
2022 platinum powerboost
I had the truck on a smart charger for 72 hours. I have a Bluetooth monitor that showes a graph. 14.3v. On charger. Yes I reset the bms several ways. Fdrs, forscan, headlight/ break.
I'm starting to realize that no one knows if bms reset does the aux battery. Also I don't think anyone knows what battery is causing the system saver. It's for sure the main battery is not the culprit.
Spiffy
Usa
Here is how my battery is now. I drove it all day. It's been sitting shut off for a few hours. I don't have remote start
Ford F-150 System off to save battery Screenshot_20241216_202846_Battery Monitor
Spiffy
Usa
Here is the main battery performance today.
Does anyone seen a problem. The constant high on left is where I had it on charger.
Ford F-150 System off to save battery Screenshot_20241216-203544
Spiffy
Usa
The lowest is the moment I turned off the truck.. it immediately dropped to 12.5v
The upward peak right at the very right is where I pressed the acc. key on enging off. That by the way is where my interior lights come on.
I turn off the acc and I get system saver message.
Jerome10
North Idaho
I think there may be a TSB for this issue. I wanna say part of the process is to determine if the 12V battery is bad, if so replace.
If it tests OK then I think they look into the charging system.
Funnily enough went searching for an older TSB (maybe from 2023 or early 2024).... there is a new one as of December 20, 2024. TSB 24-2442 " 3.5L PowerBoost - "12V Battery State Of Charge Low" Or "Charging System Service Soon" Message In The IPC And/Or "Remote Features Disabled To Preserve Battery" Message Displayed In FordPass "
