Is this something I should take in to get it looked at or just keep an eye on it?Blue smoke after sitting is usually an indication of oil settling in the intake vale or combustion chamber. Just keep an eye on oil level. My RT does it when it isn't started for a month.
Agree, Auto-Rx can clean and recondition them. 32 seals is a lot of time and labor. Strange how the seals are going bad with only 64k. https://auto-rx.com/ follow directions carefully.Valve stem seals are the likely culprit.
Before I try something like this. Is this something extended warranty will cover or does it completely need to fail before they fix it?Agree, Auto-Rx can clean and recondition them. 32 seals is a lot of time and labor. Strange how the seals are going bad with only 64k. https://auto-rx.com/ follow directions carefully.
I have used this product with a ford mod motor 32Valve engine, it had close to 100k and the smoke on startup. This worked to clean the seals, then no more smoke on start.
Oil is in the heads when you shut it off, bad seals allow that oil to leak into the cylinders, I'll be it smokes more after sitting 8+ hours..
Go to ford dealer, give service manager $20 and or doughnuts and get them to do it under warranty. Expensive, I hope the techs know how to do this, kind of a big deal to take your engine apart. 32valves = 32 seals.Before I try something like this. Is this something extended warranty will cover or does it completely need to fail before they fix it?
Hi John, If you’d like further assistance regarding the start-up concern, feel free to send us a private message with your VIN and local Ford dealer. Thank you!Is it normal to have this much smoke on startup? This was after letting it sit for 8 hours. I’m also low a quarter of a quart from my last oil change 700 miles ago
