Adronm
correct.And this wheel is a 17 x8.5 correct?
I have a set of 315 70 17 KO2s and I really like that wheel. How badly does it rub?Yes your right sorry about that typo
They are Toyo open country at3 size 315/70/17
Method 17x8.5 0mm offset
Wheel part number
MR305785161000
2.5” coil spacer
It’s pretty bad. I had to space the bumper out 1/2” trim the crash bars and it still rubs on the firewall side of the inner fender on that plastic white piece hidden under the cloth inner fender and the black plastic seam cover. I think I need to go up another inch in the front. I would recommend a 34” or smaller tire or less backspacing. I think if the tire was in more it would not rub as much. I will try to upload some photos later of the rub marks.I have a set of 315 70 17 KO2s and I really like that wheel. How badly does it rub?
Here are some more pics the poke is not too bad. I haven’t noticed any rock chips or anything due to the tire poke. Let me know if you want pics of any other angles.Do you have any more pictures? Side view. And some poke view. Really interested in how much loke that 0 offset with the 8.5 wheel gives you ?
Thanks for the info. That helps alot.Here are some more pics the poke is not too bad. I haven’t noticed any rock chips or anything due to the tire poke. Let me know if you want pics of any other angles.
I guess the rub could be worse but it is a little annoying hearing it in the cab. It gets worse when I have the truck fully loaded with passengers. Let me know if you want pics of any other angles.
Mind the dirty truck. It’s been pretty gross around here lol.Do you have any more angles of your truck. Including how much poke…Love the set up
What offset you running on the 18s?2.5” level with 18” method with 315/70/18. Rubbed a lot had to space out front bumper and trim a little
Those Toyo’s don’t come in 315/70/18? 17” maybe?What offset you running on the 18s?
thats a typoWhat offset you running on the 18s?
Yes your right sorry about that typoThose Toyo’s don’t come in 315/70/18? 17” maybe?
Do you happen to have the Max Tow Package? (Thinking of getting some 17" Method wheels, but not all 17" rims will fit on MaxTow due to the larger caliper)Yes your right sorry about that typo
Wheel part number
MR305785161000
2.5” coil spacer
No I Just have the regular tow packageDo you happen to have the Max Tow Package? (Thinking of getting some 17" Method wheels, but not all 17" rims will fit on MaxTow due to the larger caliper)
What parts did you use? Drop shackles? Pinion shims?33" 18s. "Reverse levelled"
