Reverse braking not available
Greyford
Manitoba, Canada
2022 F150 Platinum
2022 Platinum 5 litre
One day after latest update was downloaded I get the notification that the reverse braking not available and also park aid system fault. All systems are set to on in features. Did anyone else have this happen. Haven’t checked fuses yet, but seems to be right after update applied
You might not have these issues after a key cycle or 2.
Some times these kinds of errors are temporary after an OTA update.
Greyford
Manitoba, Canada
2022 F150 Platinum
Unfortunately it’s still a problem after 1,000 highway miles and two dozen ignition cycles
1000 miles in one day after receiving the update?
Sorry, I'm sure I am misunderstanding something. Do you know which update you received? And do you have a method to scan for codes?
Greyford
Manitoba, Canada
2022 F150 Platinum
No, I received the update the night before the long trip. When I reversed out of driveway to start the 500 mile trip I got the reverse brake fault message. When arriving at my destination I received the park aid fault when parking. Then two days of city driving and return trip of 500 miles and still have both faults when reversing. If I drive right up to garage door I get no beeps or input from front sensors
I have no scan tool.
Greyford
Manitoba, Canada
2022 F150 Platinum
When I pressed the camera button on the screen there was a park aid icon highlighted. I pressed that icon and it said park aid on but still doesn’t work
22Platinum
2021 KR 3.5
software engineer
Somewhere on this forum I think I learned that if you have an aftermarket spray in bedliner, the act of taking the tailgate off during the spray in process messes up the calibration of the camera in the tailgate and causes that error to occur. The dealer can re-calibrate the camera, probably under warranty.
I have both the error message (intermittent) and an aftermarket spray in bedliner; I have an appointment march 1st to get it fixed maybe. I bought my truck used with 18k on it and it had that error when I received it.
Greyford
Manitoba, Canada
2022 F150 Platinum
I don’t have the bed liner, tailgate has never been removed
Eskram
Fl
2022 F150 Lariat PB 502a
Do you have traction control turned off? Mine shows the warning every time in reverse now, if I have TC off. This started with the 6.8.0 update. If I turn TC on while reversing, it works as intended.
Jesse-Infotainment
Jesse
2024 F150 Lightning
Jesse-Infotainment
Jesse
2024 F150 Lightning
You have a code for a rear sensor. THat is what is causing the Rear brake assist error. You have several codes but the Sensor is the cause of the RBA unavailable
Ford F-150 Reverse braking not available 1708141671470
