Nothing showing in FDRS at this time.Can anyone please check if I have any update in FDRS?
1FTFW1E51MFC37912
Thanks
Hi wondering if you could look up any missing updates or module updates missing, and also if I have the FAJAK code, rear brakes squeal every AM, car is at the dealership today. thank you
1FTEW1E8XNFA81411
No updates pending OTA; these two showing in FDRS.Hi, can you check if I have any additional updates queued up.
Thanks!
1FTFW1ED0PFA72687
I see the APIM was replaced on 10/2 and the the PMI was done correctly from what I can see. Modules pending updates are below. What issues are you having?Hello.
Had my APIM replaced but still having issues. Is someone able to look up my VIN and see what updates are outstanding for all modules?
VIN: 1FTFW1E89NFB72075
Many thanks!
Modules pending updates are below. Hold off on FDRS. They started releasing the last bits of updates needed for BC 1.4 last night, but only for 2023 trucks. Save the $50 for when you are showing IPMA, PSCM and APIM updates.1FTFW1ED8MFA85585
Just looking for a look up please see if I need to hook up the Mongoose again.
Thanks in advancedeciding whether or not to pay for 3 years of BlueCruise on a 2021 Platty with 52,000 miles
thank you, i just got the truck back and they said they updated the pcm, for my hard shift issue, i'm sure it takes some time to show the update. Didn't realize there were that many modules not up to date
Thank you rugedraw!! I updated a bunch of modules via FDRS on 12/19 and am currently at Sync version 23291. Before spending another $50, do you think these would be the last updates needed to upgrade to BC 1.4?No updates pending OTA; these two showing in FDRS.
The original issues were:Nothing showing in FDRS at this time.
Those updates are for BC 1.4, but there is something still needed for it to be activated. I think maybe an APIM update to add the toggle switches the the touchscreen. I know of one guy on another forum that did these updates, and he did not get the additional features from the new BC. I would wait a bit.Thank you rugedraw!! I updated a bunch of modules via FDRS on 12/19 and am currently at Sync version 23291. Before spending another $50, do you think these would be the last updates needed to upgrade to BC 1.4?
There is no way to go back to see what updates were available on a certain date. I don't have a good explanation for the issues you are having, but on 12/19 your truck started recording some headlight DTC's as seen below.The original issues were:
- Headlight system error
- turn signal sound not audible but signal flashed normal
- turn signal hyper flash inside, but outside regular
- sync not maintaining settings
- pressing fan speed down would initiate voice command prompt
- my view menu in instrument cluster reseting on its own
Now:
- the headlight system error has come back
- parking/front proximity sensor error eventhough nothing is impeding them
- my view menu reset itself again
Is there a way to tell if those pending updates were released after the APIM was replaced or if they were pending before that?
Sounds good. Many thanks for the help. I'll book it in with the dealer to get things looked at.There is no way to go back to see what updates were available on a certain date. I don't have a good explanation for the issues you are having, but on 12/19 your truck started recording some headlight DTC's as seen below.
