Spiffy
I had it in the back of my mind that I hadn't finished. When I tried to log into ips to check I forgot my user info and got locked out. Thanks for looking
Missing a digit at the end of that vinCan someone FDRS me please? Just for Ss and Gs...
1FTFW1E86NFA0331
Thanks!
My bad....Missing a digit at the end of that vin
looks like only a couple updates for IPMA and BCMMy bad....
1FTFW1E86NFA03311
Thanks!
Cool. Thanks!looks like only a couple updates for IPMA and BCM
Hello. You do have quite a few to updateHappy Friday, everyone.
Greetings from sunny Miami.
Could someone please check my VIN when you have a chance?
1FTFW1ED7MFC98902
Thank you!
Thank you! So is this a "sit-and-wait, connect to WiFi, make sure my battery is topped off" situation, or do I need to get more hands-on?Hello. You do have quite a few to update
Hello fellow Miamian! You were sent OTA 3.5.3 on 1/24 that would have updated the APIM on that list of modules @kodiakz provided. As has happened to many people, the update timed out and failed before it was able to download the files. Wifi or not makes no difference. The problem lays in Ford's crappy OTA process and not your truck.Happy Friday, everyone.
1FTFW1ED7MFC98902
Thank you!
Thanks for the offer! I need to get some personal stuff out of the way, but I'll reach out when I'm ready.Hello fellow Miamian! You were sent OTA 3.5.3 on 1/24 that would have updated the APIM on that list of modules @kodiakz provided. As has happened to many people, the update timed out and failed before it was able to download the files. Wifi or not makes no difference. The problem lays in Ford's crappy OTA process and not your truck.
Not all of those updates will come OTA; some can only be done with FDRS. I can update the truck for you if you want. Just pay for the 2-day FDRS license that's $50 and I'll do the rest. We just have to coordinate a day and time that works for both as this will take hours to do.
Thanks for checking! Appreciate the reply!If you have access to a VCM/Mongoose you can do yourself. OTA will probably come in incrementally. OTA does not show anything in progress although your GWM failed an update in Jan and does not show one in FDRS for that ecu. Might need to give that one a little push
