Repurpose Auto Start/Stop Button?
JDaleo
Jordan
NJ
2022 F150 King Ranch
I'll be picking up a 2022 King Ranch with the "Auto Start/Stop removal", therefore where the button to disable typically sits is a blank plate. I was wondering if I could pick up the switch from Ford (https://parts.ford.com/shop/en/us/electrical/switches/switch-13285875-1), put it in place, and use the Auto Start/Stop switch for something else.. possibly to trigger a relay for train horns? I see people retrofit upfitter switches or put a switch somewhere else, but I figured if it's a momentary switch, I might be able to isolate the pins that connect when the button is pushed and use that just to trigger the relay.
Thoughts of how much of a pain that would be, or if something like this has been done?
Thanks!
Big Cam
Nick
North Dakota
2022 Ford F150 Tremor 402a
Support Engineer
That's a great idea. Following to see what you do with this.
You should be able to do whatever you want with that new switch, I mean a switch is just a switch.
mrtull
Jeffrey
Socorro, NM
2024 XLT PB 302A in Darkened Bronze Metallic, 2023 Ranger Lariat Tremor
Teacher
Thanks!
I was following a heated steering wheel retrofit. It involves a whole new HVAC console which i don't want. Seems you've inspired an alternative use of that blank space! ??
Highway 11
'23 F-150, '24 Bronco
Have you confirmed it's a blank plate? Granted, I have a 2023, but on mine they just made the button for the other button bigger to fill the hole in the panel.
JDaleo
Jordan
NJ
Yep, it's a blank. It took me a minute to realize what should have been there and the next truck over had the button.
What I am curious about, is if the harness is still behind there going to the plate that I might be able to use to grab the pins I need. If not, I'll have to find the harness for that button as well, which might be a little more difficult.
hotrodmex
Ca
22 Lariat 500.5a
Look at the "Adding Hill-Descent Control" thread for the terminals needed to make your own connection.
If you use a latching relay it could also still be used to turn something on and off.
Wonder if you can remove the blank cover and use it on the switch instead of the AS/S icon.
That switch is done internally on the HVAC module, and AFAIK there is no external control outside of the HVAC button or soft button in SYNC.
mrtull
Jeffrey
Socorro, NM
Teacher
it didn't even dawn on me to consider the controls couldn't be separated from the HVAC panel. Thank you very much for weighing in and saving me untold research time for something that may not even be possible. (y)(y)
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
Whoa, I had no idea there was an A.S.S. button on the non-hybrids. I guess it makes sense, since a lot of new vehicles have it.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
mine is a blank plate as well
i had thought about popping it out and making into a switch for rear lights..
then ...well you know :sleep:
Ford F-150 Repurpose Auto Start/Stop Button? 20220424_103054_LI
Ford F-150 Repurpose Auto Start/Stop Button? dtcs feb 19 2023 (5)
mrtull
Jeffrey
Socorro, NM
Teacher
So this brings another question... :unsure: ... can buttons be programmed to save steps? For example, I'm going to add the trailer cam into the aux camera wires. That means I have to press the camera button, then expand the menu, then click on Aux Cam. Can a button go straight to the aux cam? I know it's not a lot of steps, but at 65 mph with a trailer in tow, every little bit helps. :geek:
breulet89
Louisiana
2023 Ford F-150, 2024 Ford Expedition
Not to bring back a dead thread, but has anyone figured this out? I'd like to repurpose mine as the button for the Roush active exhaust. I don't want to order the switch if it's not possible though.
discothan
SW Michigan
2021 F150 XLT
ejection seat button for passenger, oil slick or smoke screen, drop mines or launch drones, battering ram activation just to throw out a few good ideas.
