PPK
build date is up front on drivers side valve cover, big sticker there... my truck was built jan '22 with a dec28 '21 built motor...
All I could find was the recent (Monday Sep 30) delivery hold 'advance notice' to dealers on this - no mention of the test procedure - the 'complete' bulletin to dealers now not until 1Q2025.Dealers were supposed to receive information from Ford yesterday based on proposal to NHSTA. Anyone heard any new info?
Owners are supposed to be notified between 10/07 and 10/11/2024. Waiting...
My engine build tag has a Julian date of 21022. So January 22, 2021. Very early build. 30,000 on my motor now. Curious how this thing will play out.
https://www.bronco6g.com/forum/thre...k-old-1000mi-2-7l-ecoboost.26787/#post-924343Stupid question but where is an "engine build tag?"
I think Ford and their suppliers didn't do enough research. I agree more cooling would have likely not created an issue but they were apparently using same manufacturing process as regular Silchrome. Thinking no additional cooling measures were required will cost Ford lots of money to replace or repair.My WAG is that a machining operation which is supposed to have cooling/lubricating fluid sprayed onto it suddenly stopped receiving that fluid. Supply chain/cost skyrocketed/see what happens if we cut some corners? Maybe all of the above. My YouTube University degree in metal working tells me that your workpiece isn't supposed to smoke and spark and turn blue.
That's likely correct, but I really want to believe that at some point they told Timmy the Marginal Intern to look up if Silchrome Lite needs to be kept below a certain temperature. I WANT to believe that they did that.I think Ford and their suppliers didn't do enough research. I agree more cooling would have likely not created an issue but they were apparently using same manufacturing process as regular Silchrome. Thinking no additional cooling measures were required will cost Ford lots of money to replace or repair.
The ’21-’22 Nano engine intake valve recall is a bit strange. We’ll probably never know all the gory details. In amongst the 63 documents from Ford and Eaton in the NHTSA Investigation site there is the March 2023 Ford Root Cause (1402 pages, 99.9% redacted) and Nov/Dec 2022 supplier (Eaton) Root Cause (heavily redacted) documents. The full story is likely somewhere in there, we just can’t see it.That's likely correct, but I really want to believe that at some point they told Timmy the Marginal Intern to look up if Silchrome Lite needs to be kept below a certain temperature. I WANT to believe that they did that.
