Peter P
Peter
Fort Lauderdale
2019 Ranger XLT
F-150 POWERBOOST REAR LOWERING KIT
Link to part:
https://performanceparts.ford.com/part/M-3000-PB4
Install instructions:
https://performanceparts.ford.com/download/instructionsheets/IS_M-3000-PB4.PDF
Part number: M-3000-PB4
Retail Price: $314.00
Provides a leveled sport truck stance by reducing ride height approximately 1.5".
  • Fits 2021-2026 F-150 2WD and 4WD Super Cab and SuperCrew equipped with PowerBoost
  • Kit includes laser-cut, steel lowering shackles with urethane bushings
  • Improvements:
    • Grease fitting added to lower shackle tube
    • Bushing grease groove
    • DOM center tube tolerance
  • NOTE - NOT COMPATIBLE WITH:
    • F-150 Lightning
    • F-150 Tremor
    • F-150 Raptor
Ford F-150 Rear Lowering Kit (Ford Performance) released for F-150 PowerBoost M-3000-PB4
Kritas
Morris, AL
FI50 3.5L PowerBoost
That's great news, and I appreciate the heads up. I'm waiting for my Ford Reward points to be credited to pick up a set.
Lula Mae
2025 F-150 Lariat Powerboost Antimatter Blue
What is the advantage of this over removing the blocks over the axle?
FirstNewFord
New Jersey
2012 Ram 1500 express hemi 4X4, 2025 F-150 XL reg. cab. short bed V8 (pending)
I was wondering the same thing. Isn't it easier just to pull the blocks out? My understanding from most who posted here is that they just removed the blocks and didn't need to change the shocks, bump stops or mess with the pinion angle. Even the stock U-bolts have enough threads for the nuts to be higher up. The blocks on my '25 RCSB 4X4 look like they are about 1 1/4". I haven't pulled them yet. Still waiting for a consensus.
bhom
NJ
21' Platinum PB
i just removed the rear blocks on my 21 Platinum PB.. no issues. I run 5100s and also tow. The truck still has a rake, but it looks far better than did stock. I am currently on stock u bolts with some washers, but i also ordered a set of shorter U-bolts have been pretty lazy to get around to it. It's probably been a year since i purchased them.
ynot
tony
2020 f150 lariat
Ford F-150 Rear Lowering Kit (Ford Performance) released for F-150 PowerBoost trac-2-in-rear-lowering-shackles-on-your-mustang-1
https://www.americantrucks.com/maxtrac-2in-low-shackles-9704-manu-install.htmlPARTS LIST
LOWERING SHACKLES: 2
Before the installation of shackles, it may be required to remove the trailer hitch to access the shackle access the shackle mounts.
1. Jack up the rear of the vehicle using floor jacks, prepare to install both sides at the same time
to avoid binding spring bolts.
2. Support the rear axle with floor jack under the differential.
3. Remove the lower shackle bolts.
4. Jack up the rear end enough to remove the upper shackle bolt.
5. Lightly grease the supplied bushing / sleeves and install the new shackle, with the
6. Install wheels, and lower the vehicle to the ground.
Its best to cycle the suspension and take the vehicle for a drive before observing the amount of drop provided by the aftermarket shackles.
After Installation:
• Check torque on all fasteners for proper torque.
• Readjust headlight settings to account for change in height and angle
• Re‐check torque after 500 miles.
EL5_Zero
CA
'24 F150 RCSB Antimatter Blue
I.W. Local 433
Link to part:
  • Improvements:
    • F-150 Lightning
    • F-150 Tremor
    • F-150 Raptor
This is a solid ENGINEERED kit with complete instructions, not just shackles. When I installed my 3/5 Kit from IHC, I had constant vibration that took me a while to figure out. I contacted IHC and asked if the transmission required shims to get the driveline angles back into spec. They responded saying the axle perches aligned everything.
I did my own testing and added a 1/2" spacer at the transmission mount similarly designed to the one found on the Ford kit and it solved my issues. It's amazing to see that even a minimal 1.5" rear drop requires a transmission shim, let alone a 5" drop.
AF RET
Steven
Battle Creek, MI
2025 Ford F-150 XL
After Installation:
Do you have any before and after pictures?
AF RET
Steven
Battle Creek, MI
2025 Ford F-150 XL
Do you have any before and after pictures of yours?
EL5_Zero
CA
I.W. Local 433
Here's a pic of when I picked up my truck, and with the 3/5 drop. I didn't document the shim I made to align the suspension.
Ford F-150 Rear Lowering Kit (Ford Performance) released for F-150 PowerBoost IMG_1070
Ford F-150 Rear Lowering Kit (Ford Performance) released for F-150 PowerBoost 20250409_140031
HDT05
2024 F150 Lariat 502A FX4 5.0
I like those rims.... what are they? Any chance you have a close up pic or side view of your truck handy?
Thanks
