programming map orientation
DT400
Darrell
The Ford dealer did an update on the infotainment system and one thing that is different is the navigation map now defaults to an angled view. It was a straight down view which I preferred.
is there a way to set the default orientation? I can reset it when I start the truck but it has to be done every time.
Thanks
Darrell
KBKEITH
My 2022 doesn’t have factory nav, but my former 2021 did. If I recall correctly, there is a way to toggle between 2D and 3D views. I’m sure someone will chime in to fill you in on that.
Porpoise Hork
Bret
IT Sys Admin
One of those If it were a snake moments... I can't tell you how many times I have done stuff like that..
dolsen
KY
2022 Rapid Red 701A
Well I feel like an idgit....took 1 minute or less once i looked in the nav menu...DOH.
Darrell
Well the issue is it automatically defaults to 3D heading up every single time you restart the truck, AND the nav no longer maintains the zoom you set, it always reverts back to its “auto” zoom which is incredibly frustrating to me
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
Darrell
and in a few days it will switch back to 3d...mine does that at least once every few weeks
i have idea why
DT400
Darrell
It's not the zoom level that bothers me it's the fact that it defaulted to 3D when I wanted 2D, I did find a setting in the Nav menu that set the default to 2D....
Darrell
dolsen
KY
2022 Rapid Red 701A
Darrell
It’s both that bother me. I have looked all over the settings (or so I thought) to see if I can change the default. Can you point it out for me please?
DT400
Darrell
Sure
On the Nav screen upper left tap 3 bars-->map orientation...
Darrell
dolsen
KY
2022 Rapid Red 701A
Sure
Darrell
I did the manual updates to get the latest sync version (22228 rev 539) and that does not change the default setting for me. It’ll change the orientation while the vehicle is running but will reset everytime I restart.
I’m guessing we don’t have the same sync version then.
DT400
Darrell
Interesting. I should have the latest as the dealer did it 3 weeks ago..unless another is out...not sure how to check the version I have....can you tell me?
Darrell
dolsen
KY
2022 Rapid Red 701A
Darrell
Settings > General > About Sync
My software version is 22228 revision 539
DT400
Darrell
Well it worked once or twice I think but now is always goes to 3d when I start the truck. Why do updates always seem to be a step backwards??? It's frustrating.
I have the same version.
Darrell
rob
rob
sunnyvale
f150
did you ever get default to stay on 2d north up
