Problem: Steering Assist Fault Service Required alert
rico
Duisburg, Germany
F 150 , Platinum 2021
.Hello Ford community, I just got an error message on the display of my 2021 Platinum Lobo. Can someone please help me? It says "steering assist fault, service required, dismissed alert." And when I turn the car off, it says "please turn ignition, off-topic start engine..." It would be great if someone could get back to me quickly. The car has been running perfectly so far, without any problems. It currently has 95,000 km on the odometer. Regards, Rico
Ford F-150 Problem: Steering Assist Fault Service Required alert PXL_20251108_081000038
Ford F-150 Problem: Steering Assist Fault Service Required alert PXL_20251108_075007518
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
You are having a battery issue. You could try charging your battery but the 2021 was known for coming with a bad batch of batteries. Even replacements from ford were known to have same issue. I would start with a good replacement battery and make sure you reset the BMS module after battery change or charge.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
To perform a manual 2021 F-150 BMS reset, turn the ignition to the "on" position without starting the engine, then quickly flash the high beams five times, followed by pressing the brake pedal three times. If successful, the battery icon on the instrument panel will flash three times to confirm the reset. “
rico
rico
Duisburg, Germany
Hi my best friend... whoever you are, you've been a great help. The new battery is installed, and the trick with the headlight flasher and brake pedal also worked. Thank you so much for your help. Where do you live, by the way? I live in Germany. So, thanks again, and have a great weekend!
Rico
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Rico
Indiana
I’ve visited Germany a few times
Frankfurt is beautiful, need to get back some day
rico
rico
Duisburg, Germany
Indiana, OK, I've been to Boston once, but that's it so far. I'm from near Cologne. I just noticed, as I was turning off the car, that this error message regarding the battery was still displayed.
JmcnealFL
Jack
2021 Lariat Sport
Came to say I had the same issue and it was in fact a bad OEM battery. Glad you were able to find a fix
