amschind
I think that the 7.2 kW is the biggest argument for the hybrid. The power and mileage are nice, but the ability to run whatever you've got wherever your truck is parked is pretty impressive.
IMHO, if you NEED that extra 30-50# payload, then F150 is not the truck for you. You need Super Duty.The upgrade is also a payload hit, and people try to pinch "pennies" on those yellow stickers so much as to give up max tow because the gen13 options sheet showed it as a 14# payload hit (even though the best info on it showed it was below-sprung components). (It wasn't until way later that someone inspected under the powerboost and found exact same stabilizers and axles as a max tow EB)
Intuitively, the beefier inverter and way thicker cabling I'd guess are 20# or so but when trying to reverse engineer the 7.2kW upgrade weight, it may be as much as 30-50#.
So if you don't plan to use it, it can save some $ and #.
That may be so, but for me, if the 7.2Kw generator added too much weight and I couldn't select that option, I would have keep my old truck which had the HDPP option.The upgrade is also a payload hit, and people try to pinch "pennies" on those yellow stickers so much as to give up max tow because the gen13 options sheet showed it as a 14# payload hit (even though the best info on it showed it was below-sprung components). (It wasn't until way later that someone inspected under the powerboost and found exact same stabilizers and axles as a max tow EB)
Well I wasn't worried, I believe I was trying to help other people here that were extremely concerned about every option's weight. I went with the 7.2k.IMHO, if you NEED that extra 30-50# payload, then F150 is not the truck for you. You need Super Duty.
If it’s not stated on the window sticker, it has the standard 2.4 KWHI looked at a powerboost the other day and it only had one plug in the bed? And the sticker doesn't say which one it has 2. 4 or 7.2
