toyko joe
5-w30 full synthetic as per the factory recommendations. Running stock Michelin tires at 41psi (above the door code by 6psi), pretty even wear pattern though.
I'm in Colorado too. What's your build date, and which dealer did your service?2021 Powerboost. Had the rough shifting issues from 1-3 also. Took the truck in to the dealer and this is what they did yesterday.
I’ve only driven a few miles since I got it back, but it is now very smooth.
3/21 build date. Phil Long Motor City in Colorado Springs.I'm in Colorado too. What's your build date, and which dealer did your service?
Thanks. I asked because I was curious as to whether the fix was being applied to trucks outside of the build date specified in the TSB. I have a 6/21 build.3/21 build date. Phil Long Motor City in Colorado Springs.
I have experienced the same thing a number of times. Very dangerous. Have you found a solution?Mine was good for the first few thousand miles but now that I'm at 12K it's getting to be dangerous. The weather is cold now so I'm sure that is part of the problem but even after it has been driven for a while it's clunks really hard at times. On top of that I have had it become unresponsive when pulling out into traffic. The other morning I pulled out of my driveway with the engine on and as I was accelerating all power cut off. The engine was on but no response from the pedal for 20 seconds or so. It was so bad I had to pull over and wait for the pedal to respond.
I love the truck but the bugs are starting to become a problem.
Yep, I've explained it to the SA, and doesn't make a difference. The funny thing is I've had two SA ask me what is TSB? Is it an error code? LOL!!! Oh yeah, I've also been told no error code they can't work on it. I'm just done with Ford unless someone knows how I can reprogram it with ForScan or who I contact to light some fires up the chain of command at these places.Amazing ^
Applying an update to the module takes minutes. Literally. They'd be done before you finished your coffee.
