I had someone do it for me using Forscan and have no idea what they did. I know you need an OBD cable to plug into the truck and windows laptop. You should be able to do a search and find more info. Or search for Jesse infotainment and send him a direct message.Is there a way you can show me exactly how you
I’m assuming you mean 295/70/18? If so, that’s +6.8% difference between the stock 275/65/18. If you are showing 17mpg, multiply by 6.8% (1.156) = 18.15mpg. The lift and bigger wider heavier tires are killing you. Width probably hurts the most, then weight. Unsprung weight is a killer to power and mpg. Try a lighter tire with max width of 10.8”. Taller is ok as long as width and weight don’t increase drastically. I had a 2004 F150 and went from stock size to an E rated (10ply) tire that was larger wider and much much heavier. Mpg went from 19.5 to 13.5 and the ride was horrible because of the stiffness of E rated tires. Made that mistake once and never again. As far as suspension, I also leveled with pucks. I think that had maybe a .5 loss in MPG at the most. The tires were the killer.That’s the same as me but I’m getting like 16, 17 mpg. I do have a 3 inch lift and LT 290/270r18. I don’t speed. I do not know what to do. I have never hit 20 mpg in that truck. It’s a gas guzzler
That’s a +5.1% difference. Look up the specs on oem tire weight vs your existing tires.I meant 285/70R18
