This is interesting…I have a ‘21. 33k miles on it now and never had a single instance of deep sleep or battery issues and haven’t paid any attention to the 12V. I drive it often when I’m home, but I haven’t had issues when I take work trips leaving Monday morning and returning Friday night.Keep your HVAC blower on setting 5 or higher to avoid having the truck consume your 12v batt during normal operation. (yes this is a real thing)
#fordLogic
Since your post last week I have been keeping track of this every time I drive. I’ve also tested it out here and there by changing the settings. I have to report……. You are 100% correct.Keep your HVAC blower on setting 5 or higher to avoid having the truck consume your 12v batt during normal operation. (yes this is a real thing)
#fordLogic
Managed to knock some of it out earlier than I expected.The blower speed being involved in this has to be some sort of mistake. Not saying your observations aren't real, just that if real, it has to be some sort of glitch.
Whatever weird charging parameters they've set, thats one thing. Requiring specifics for charging other than key on, makes no sense and the blower motor set to 5, is just out there.
Don't think I can get do it today but I'll run what tests I can do tonight or tomorrow.
My concern for monitoring voltage only is the assumption that if "charging voltage" (14.X) is present, that the 12V battery is receiving "charging current" in sufficient quantity. (amps)Managed to knock some of it out earlier than I expected.
I can't explain why but my results have a more normal result re charging and blower but only measuring volts at this time.
Truck was undisturbed for ~18 hrs. Last driven, several days ago.
6:15 a.m. Popped the hood.
Engine batt = 12.12V per digital multimeter.
Key on, fob in truck, AC off, ICE off, lights off.
14.45V
AC on, fan speed 1, ICE came on with AC.
14.46V
Fan speed 2 = 14.46
Fan speed 3 = 14.44
FS 4 = 14.43
FS 5 = 14.43
FS 6 = 14.42
FS 7 = 14.41
FS 7 plus both seats max cool = 14.41
ICE off, AC auto, FS 3, seats off = 14.44
Key off, fob out of truck = 12.64
6:34 a.m.
Thanks for your explanation of how the PB system works. Is there a detailed technical discussion of the electrical system anywhere? It seems to be a real black box.Yes, it IS the energy in the Hybrid battery that is providing current for the 12V system in the truck. It provides both the current that is being consumed by the 12V components, as well as the current necessary to "charge" the 12V battery.
Huh, never made the connection. - Bob and Tom, The Mr Obvious Show.
For good measure I just place my truck on a trickle charger occasionally. The Optima 400 is the charger of choice for me. I place a yellow towel on my door handle to remind myself to unplug the charger before driving.
