power tailgate goes to sleep?
aaexpert
nh
22 f150 platinum
I use the tailgate often each day using the tailgates button or manually closing the gate. Ive notice several times the gate button(on the tailgate) doesnt 'power' open or close. Tried going to the dash button or using the keyfob and it beeps but doesnt work. Not sure what combination works but Ive manually closed the gate, used the Key fob 'unlock' button a few times and then the power gate button works.
Does it go to sleep or go out of sync when manually closing it?
Wvmtneer
Usa
Ditto, but i do not have power close.
ColoradoHunter
Dennis
2021 F150 King Ranch 4x4
Yes it does seem to go to sleep if left open for more than a few minutes. I've noticed I have to lift it twice to get it to close if it's been open very long and the truck not running.
Mash150
Dale
North of the 49th
21 King Ranch, 157, SQ , PB
Happens on my 21 with the power gate. As mentioned, it seems the longer it’s open the more likely it loses power. I use my tailgate often just as a work surface, so it’s open a long time. Had it never want to power up a few times. Opened and closed one of the truck doors and it powers right up. So, something like sleep mode I guess.
notabot
Americas
Yes
Happens on mine every now and then. Hit the button on the tailgate and nada. Check pocket for FOB. Check. Hit again and it works. Go figure...
RossRR
Ross
Minnesota
I use the tailgate button on the fob regularly and the tailgate frequently responds with three beeps on the first double push of the button but always operates on the second attempt. This is true whether opening or closing the tailgate. I don't consider it an issue to be concerned about.
Pete6114
Pete
Ontario Canada
2021 F150, 2023 Lincoln Aviator
Retired Ford employee
Mine likes to snooze frequently too, usually when i try to open it and a few times while open with the truck unlocked.
