OTA updates
fxo
Frank
Cameron Park, CA (Northern California)
2025 F-150 Lariat 4x4 Long Bed
retired engineer
I have both the IPC (dead instrument panel issue) and Brake Boost system failure (also software it seems), waiting in the balance, but it is not clear to me if OTA is just there as long as I have my Wi-Fi setup to my house, which I do.
Or does Ford tell you for sure, we don't want to brick your truck , so you must take it in. This process or what constitutes what is not clear.
Does anyone know how Ford does it?
TIA!
mkinttrim
Soldotna, Alaska
2021 Lariat 4x4 501a
My dealer wouldn't tell me shit. A cpl of guys on here have access to Oasis and fdrs. They told me that I was way behind on updates and helped me get caught up last year on my 21. Dealer refused to even attempt an update.
TIA!
It will be sent OTA eventually, but no telling when that will happen.
fxo
Frank
retired engineer
Alright time to send an X (Twitter) message to Jim Farley , enough is enough. I am sure he's got some intern reading that, but still.
KBKEITH
I had the brake boost taken care of recently via mobile service and on Tuesday they are coming back to do the IPC update. Both are supposed to be rolled out via OTA, but not sure when. Plus, my tech told me the brake boost update was pretty large so it perhaps might be iffy for some via OTA.
  • Like
Reactions: fxo
boots
fl
2025 f150 powerboost
I took truck into dealer and had the seat belt chime, dashboard, brake boost and the axle bolt recalls done, the axle recall they do an inspection and order parts, who knows when the parts will show up. they gave me a loaner car, they had the truck all day.
  • Like
Reactions: fxo
gagliano7
Joe
Monroe NY
2023 F150 4x4 XL STX BAP 5.0 3:73
I have had updates done not at my house so I don’t think you have to have your WiFi connected.
roadPilot
SE Michigan
OTAs are NOT delivered via WiFi. Why people (not you) continue to post false information is beyond me.
Vater
James
Denver
2021 Limited Powerboost
Had the same issue on my 21, PB Limited, ie, at least 10 modules with updates issued that Ford had no interest in updating. For the dealers I have spoken with, they don’t want to update modules unless there is a specific directive from Ford to address and known problematic module, then they will do that module. If it works fine with existing modules, they won’t touch them unless the vehicle is new, new. That said, I updated all of mine myself anyway.
roadPilot
SE Michigan
Some OTA updates are delivered via WiFi, some are through the built-in cellular, but it likely depends on criticality and size.
Nope. Only one was sent via WiFi, and IIRC, it was to fix OTA updates over the TCU. Unless something was changed in the last ~6 months or so (which I have not heard of). Been doing this for years.
roadPilot
SE Michigan
Exactly 100% correct. Unless you have a great relationship with the dealership owner (I do). 😉
I splurged for the Mongoose Plus and update my F150 and Dark Horse when I feel the urge or find out an important fix/update is available.
fxo
Frank
retired engineer
While the vehicle's built-in cellular modem is used for the initial "handshake" and to check for OTA updates, connecting your vehicle to an external Wi-Fi network (like your home Wi-Fi) is the preferred and often faster way to download the larger update files. Ford's official support pages and owner forums both recommend connecting to Wi-Fi to ensure the quickest and most reliable download process for the OTA.
You can go search the Ford site where this came from...
Looks like you learned something.
