OTA update wiped tune
I'll wait until you guys report back on the new tune and how this update behaves. My EV has new PCM/motor control updates available for it too so not sure if this update will do much for the PBs.
MallCrawler
SC
2008 Maxima, 2022 Tremor on order
I'm waiting to hear about this one.
Unfortunately so am I. However during today's daily futile update check I did get a brief "updating device files" screen. Usually it asks to confirm updates. Time to go see if it can properly read codes and if so I'll try flashing the ECU.
22Platinum
2021 KR 3.5
software engineer
I hadn't plugged in myCalibrator since I flashed probably 6 months ago now; this thread prompted me to plug it in and it did update some things (but it was my first time seeing it so I am not familiar with what happened.)
I am almost of the opinion that myCalibrator has the new strategy on it and I can go flash up to the latest but it would be nice for Livernois to put out some guidance.
You plug in, it should wipe it and then you have to go redownload your files off the PCM and resubmit like you did when you bought it. Did you call them to get the wipe?
MallCrawler
SC
No dice.
My curiosity got the best of me and I went out to the truck with my obdlink and laptop. Forscan wanted to update obdlink firmware. Crashed during update and now adapter is unresponsive ? . Comedy of errors
MallCrawler
SC
Shoutout to the makers of the OBDLink EX for having a well documented process for recovering from a firmware flash failure. Revived it and pulled my PCM info. 100% confirmation of tune overwrite.
Going to submit a device reset and tune request to Livernois.
Eskram
Fl
2022 F150 Lariat PB 502a
I have not updated, but for the benefit of others - can you post more information here on the process?
When you run the latest forscan it will update the adapter. Only if it fails is recovery needed.
MallCrawler
SC
2022Bruce_L
Summerville, SC
2022 F150 XL RCSB
Whipple replied:
2021-2023 F150 5.0 trucks with Whipple Tomahawk tunes will not get any over the air pcm updates with our calibration loaded .
Thank you,
Whipple Support
That's great news. I was informed the other week about OTAs wiping tunes but fortunately my truck is more garage princess than anything so I've not even done the radio update
Ford F-150 OTA update wiped tune 1715709074447-mi
went ahead and disabled auto OTA in the meanwhile.
Ford F-150 OTA update wiped tune 1715709126913-wh
aaexpert
nh
22 f150 platinum
since the last 2 updates this month, I can tell my tune is no longer there just by the lack of the pedal response HOWEVER my shifts are smooth as can be for the first time in YEARS and i wont bother retuning it.
sbacpo
2023 F150 Platinum, 5.0, BAP
Same here.
MJG44
Toronto
Get a pedal commander. One of my fav mods and changes the driving experience.
PW2150
Phillip
2021 f150
Construction Superintendent
Has anyone seen or heard of a hp tuners unlocked truck having problems with the OTA updates?
thanks
PW
