OneFast440
AZ
2023 Raptor R
Looks like Sunny will be pushing out a fix later today.
In the meantime, try deselecting your car under "Vehicle", then restart the car.
Ajzride
Automation
That will most likely leave you in dash cam. They are working on it.
Fourthewin
Andrew
Kansas City
2021 F-150 Platinum
Real Estate
Ya, this didn't work for me. We even thought it might be the extension cable so I direct wired under the dash. Still same issue, it waits for controls to start. Deselecting the vehicle only gets it to dashcam mode and won't fingerprint.
Ajzride
Automation
This should be resolved in a few hours, but if you are in a rush, you can make a fork and hardcode your fingerprint (be sure to not select a vehicle from the menu)
Fourthewin
Andrew
Kansas City
2021 F-150 Platinum
Real Estate
That was absurdly simple.
Ajzride
Automation
You can also follow that document if you want a fork that won't automatically update. Then you will only get updates when you go into GitHub and click the "sync fork" button.
Ajzride
Automation
Anyone wishing to stay on sunny pilot can use the branch switcher to move to a roll-back branch that works for F150s.
from the software menu, you can "check for update" and then "select target branch" and choose dev-c3-rollback-test-prebuilt
Svt54
Brandon
Southern Indiana
23 F150 XLT Sport Crewcab 4x4 3.5 Ecoboost
Union Representative
@Ajzride I got my 3x installed and got it up and running on the rollback branch. I went with the settings in your pdf. The only question I have is what driving model do you suggest?
Ajzride
Automation
for highway, FarmVille.
for mixed LAv2
Fourthewin
Andrew
Kansas City
2021 F-150 Platinum
Real Estate
So basically my hardcoded fork is locked in unless I decide to manually sync on GitHub? This is precisely what I wanted!
Fourthewin
Andrew
Kansas City
2021 F-150 Platinum
Real Estate
Yes.
You will want to update in the next week or two ;)
Are they going to accept your updates and push them out?
Awesome, let us know when you get the approval and it pushes out!
travisN000
Travis
Oregon
2021 F150 Powerboost CCSB
Any commentary on the dash cam functionality of the Comma 3x?
Does it have any crash detection, break-in detection, or 'sentry mode' parking monitor type functionality? Front and rear recording? Are these type of features in any of the openpilot forks?
Ajzride
Automation
Crash detection yes. Sentry mode..... eventually. You can see some of the bones of that code in there when you peek around at the code. I think some forks used to have it, because the Comma3 Had an NVME slot and you could put a 2TB drive in it. But to make room for the red panda in the Comma3X the NVME went away and you now only have 64gb of onboard storage space (less than 5 hours at the quality the cameras record at). Several of us have theorized about adding USB-C storage, but no one has followed through with it yet, we all have bigger fish to fry at the moment.
