there are many accessories that can be inserted. Most commonly tie downsI ended up reading the description again. It says I need an interface kit which is a different shaped attachment. Can I swap what I have for those? Not sure what the ones on my truck are even for?
Thanks for the info. I will order the plates.The picture in the first post is is more or less a generic tie down or attachment point. You can tie a rope to it or a ratchet strap etc. It may take a bed divider, but not sure. It doe not accept the Boxlink locking cleat / hook. The plate for those is different, and does take the cleat and bed divider. A set of 4 of the boxlink interface plates was in a box under the rear seat in my 2024 F150 Platinum. The dealer said the cleats / hooks are no longer provided, and you have to get them separately.
Look at eTrack stuff first.Thanks for the info. I will order the plates.
