OBD Fusion PIDs
The pressure probably does fluctuate and the sample rate could be different to account for variance. They seem close enough.
More interesting is having that on center screen. I don't have an iPhone but that is cool. :)
Apparently per Reddit this works with Android Auto. At least in another modern car so should work in all...
I'm hesitant to buy an app then have to buy the enhanced add-on but some might be interested. No freebies in this app.
Did see they confirm they are developers of OBDLink app.
OBD Fusion for Android is brought to you by OCTech, LLC, the developers of TouchScan and OBDwiz for Windows and OBDLink for Android.
waltztj
Walt
2021 Ford Ranger
I hope someone can help. I am looking for the PID for transmission gear. I am using the OBD Fusion App, with OBDMX + adapter.
SilverPigeon
Australia
There are at least two:
1. Ford/Lincoln/Mercury > Powertrain Control Module > Gear Commanded and
2. Ford/Lincoln/Mercury > Powertrain Control Module > Transmission Gear Engaged
waltztj
Walt
2021 Ford Ranger
Thanks
Fun thing if you use both you can see it command the gear and a delay before gear is engaged. :)
@waltztj you'll see weird number for Park, Neutral, Reverse. The rest of the time it will show the gear number.
TJSparky
WA
Does anyone know the correct PID for engine oil temp that actually works?
