NOCO 10 with a Duralast Platinum Battery - not charging
YzermanTopShelf
Tom
California
2021 F-150 Lead Foot Lariat Powerboost
My battery is a Duralast Platinum which a installed just a few months. When I hookup the NOCO 10 to the Duralast and set it to 12V AGM the 25% Red LED blinks and then the standby LED blinks - alternating back and forth. At first I thought the battery might just be very low (which is odd since it is so new), so I left it over night but the charge didn't go up at all. I checked google and reddit for anyone else who has seen this behavior but couldn't find anything. I also tried Force Mode but that doesn't appear to have any effect either. BTW, the truck runs just fine so the battery can't be that bad.
Appreciate any help! Thanks!
Kidder
DFW, TX
2025 F250 Lariat PS HO
I have the same charger. and it works fine (I have the stock battery). I assume you set it to AGM. I originally thought you had it connected to the truck and thought you may be charging it wrong but I just noticed it isn't connected at all. Maybe it's in repair mode? Read the manual about how to get it out of that mode. https://www.manua.ls/noco/genius-10/manual
Borchelt
Tom
Boise, ID
2021 F-150 XLT, Powerboost Hybrid
I also have a Powerboost with a new Duralast Platinum battery. As the above video implies, make sure you have the Neg, connected to the BMS module and not the battery terminal itself. Here's my earlier post on that.
Added a NOCO Genius 10 charger permanent battery connect. I hate having to route an extension cord, open the hood and deal with positioning the clamps and then unhooking. I added a NOCO permanent battery connection and NOCO extension routed to the driver's side since that is closest to the workbench outlets. Hate having cords on the floor. When connecting to the battery, make sure you connect the black (neg) eyelet above the BMS module as shown by green arrow. If you connect to the negative terminal on the battery directly, it will bypass the BMS - Red Arrow. Might do a custom job and route the charger connection out through the fender XLT badge for a cleaner look and totally out of the weather. The end cap should protect it for now (garage kept) until I get some time for a custom fab.
FirstFord
South Central Missouri
The video you attached is very illustrative - you've got a tough one to figure out! I'm kind of a fan of the NOCO chargers, and I have quite a few. And in the past I had an issue that I just could not figure out and had to contact NOCO support. I'm pleased to say that they were responsive and helped me figure out the issue (a fuse was not fully seated).
I kept the communication with NOCO support, and have posted part of it here, as it may be applicable to your situation:
"If the Standby LED is illuminated, this means that the charger is in Standby mode due to it not recognizing that it is connected to a battery. This can happen when there is no battery connected to the charger, if the voltage on the battery is lower than the recognition threshold (1V), if the connection to the battery is faulty, or if the inline fuse is faulty or loose in the fuse housing. "
The fact that your charger indicator lights are actually cycling between Standby and 25%, makes me wonder if there is not a loose connection (including an issue with the fuse) somewhere. Isolating the battery as you have (bypassing BMS) I think is a good idea for this specific troubleshooting exercise. Outside of that, I have no other ideas other than to contact NOCO support. Good luck!
