No start after running generator
KD10
Houston, TX
2021 F-150 KR 3.5
Need some help. I’m 70 miles from the house and can’t get my ‘21 3.5 eco boost to start. It’s been running fine all day while using the onboard generator at a tailgate then suddenly died. Will turn over but won’t start and just reached the crank limit. Plenty of fuel and battery appears to be strong because it will turn over without issue. Any ideas on what I can check to get it home? Appreciate the help.
Dave541
Oregon
2022 Ford F-150 Lariat Powerboost
Driver
I’d try disconnecting the battery for a short time. Not sure if you could go grab a bite to eat or do something to keep you occupied for a short time to let the system reset? Other than getting it towed to the dealership. ?‍♂
KD10
KD10
Houston, TX
2021 F-150 KR 3.5
Thanks Dave, gave that a shot and it didn’t work. Seems like the fuel pump since I can get it to start for a quick second, then acts like it can’t get enough fuel. Anyone else lose a fuel pump at <30,000 miles?
Dave541
Oregon
Driver
Did you figure anything out? Blown fuse maybe? Unless you have a OBD to plug in with a smart device, you’re kinda screwed.
JEB
US
2021 F150 Lariat PB 502a
That is a really bad idea. The Powerboost has an auxiliary battery. Disconnecting the starting battery won‘t reset the system. What it will do is drain and possibly damage the auxiliary.
Kodiak
I think he said he said he has the eco boost not the PB version.
JEB
US
You’re right. I was looking at the truck of the person recommending disconnecting the starter, who owns a PB.
KD10
KD10
Houston, TX
2021 F-150 KR 3.5
Thanks for the responses. Ended up having it towed to the dealership to get it looked at today. I’m pretty stumped on what it could be but it almost felt like it couldn’t get adequate fuel supply. One time it turned over for a few seconds then acted like it was starving before quitting. In other news, the Ford Roadside service worked really well. I’ll follow up once we get it figured out.
KD10
KD10
Houston, TX
2021 F-150 KR 3.5
Just a follow up for anyone that may run into the same issue. It did end up being the fuel pump. Service rep said he has seen a slight uptick in fuel pump issues on the ’21 3.5 eco boost lately. Took almost a week to get the part in but resolved the issue. Looking back on it, I did notice a slightly rough idle at times that may have been an indicator but it was never bad enough to let the engine die. I can’t complain too much, it’s the only issue I’ve had since owning the truck.
