amir_gh22
Hi all,
I would like to disable cornering function on my fogs. They come on when I turn the steering wheel or use turn signal. I have a 2022 XLT with LED reflectors and LED fogs. I want to keep DRL on the fog and headlights. I would like to just manually turn the fogs off or on when needed. I went to forscan today and there are multiple settings on the BCM. Not sure what I need to edit
Someone disabled cornering fog lamps using below values for 2023 Platinum. Mine is XLT I feel like its different. Any suggestion?
726-39-01 03xx xxxx 00xx
726-42-01 xxxx 0404 xxxx
Mine As built has different values. Please see below
Any chance I can edit below? If so, what do I need to select?
Thanks
Thanks
