SnareDrum
- Joined
- Apr 29, 2022
- Threads
- 8
- Messages
- 122
- Reaction score
- 85
- Location
- Connecticut
- Vehicles
- 2022 f150 lariat
- Thread starter
- #1
Anyone running this with their setup who could possibly offer me some insight? I had the factory 8-speaker B&O and removed it. I replaced the factory amplifier with the Mobridge DA-G2.Pro A2B Preamp & DSP, Kicker amplifier and Kicker speakers (KS components in the front and KS coaxial in the rear). It works well and sounds good, but I'm unable to get the chimes to play through the speakers.
Obviously there's 2 DTCs in Forscan with the APIM and the ACM - Lost connection with Module D (I'm guessing this is the factory amp). Not sure if there's code I need to change to address this. I've cleared the DTCs but they return.
I reset the APIM, ACM, and IPC yet all the chimes continue to play through the cluster. In the DSP I have the chimes set to play through the front speakers so I don't think its a DSP related config issue.
One other thing and I'm not sure if this is an issue with my time alignment or maybe a defect with one of my component speakers, but the tweeter on the passenger side has this really nasty "EEEE" sound around 8khz. I had to cut out at least 12-14db and it's still slightly audible. I did time alignment with my laser measuring device in the driver seat aiming the laser at the center of each woofer from about where my head would be.
