Manually rolling through gears in e-only...
I'm able to get better results while not holding the phone and driving -- I short shifted some of the gears and couldn't quite keep the electric motor at full power, need to make a vid of the stats so its utilization can be seen. The road is flat. This used 18% of the HVB capacity (total, not usable). The average amount of power used was 75 amps, or 20.85kW, which is about 60% of the actual power output of the electric motor (shown as discharge limit 35kW available at start, still 34kW ready at end).
Start variables..
Ford F-150 Manually rolling through gears in e-only... 1679604823491
End stats right as ICE kicked on
Ford F-150 Manually rolling through gears in e-only... 1679605036994
