Running ICE only in Powerboost?
STL04
Morhan
St. Louis
2022 Powerboost
Does anyone know if there is a Forscan hack to eliminate EV driving and start/stop?
I added an AFE cold air intake, CV intercooler, BOV, Catch can, and Borla S type (I'll tune later this summer and waiting on the Ford Performance shocks to arrive) which make this truck F'n awesome, but the EV/Start/Stop take my fun away.
As I read from another poster in here- "it's boost season."
If you are tuned and in Sport mode, the ICE starts with just letting off a bit with the brake pedal.
So you have ICE before the light is green.
STL04
STL04
Morhan
St. Louis
2022 Powerboost
Thanks.
I typically run in Sport, but I will give this a run.
STL04
STL04
Morhan
St. Louis
2022 Powerboost
I'm not tuned yet, but plan on doing one or two options that are ICE only.
The start/stop just gets to me for whatever reason.
But a Hybrid vehicle is a stop/start animal by its DNA. Curious why grab a Powerboost then?
Regardless, the Powerboost doesn't shy away from a quick sprint. Makes no excuses. :)
STL04
STL04
Morhan
St. Louis
2022 Powerboost
I originally bought this for low-end power when towing and gas savings, but the power is too much fun to ignore.
(and the Borla S-Type sounds really good at a stop light)
Samson16
Orlando, FL.
Aviation systems
Have you tried gently power braking it while in sport mode? Might kick the engine on.
STL04
STL04
Morhan
St. Louis
2022 Powerboost
I have, and it seems like it confuses the PCM somewhat.
It will kick on briefly, but it acts like it's fighting me after one or two times.
Samson16
Orlando, FL.
Aviation systems
Right! It does do that I forgot lol
ebrake and gas maybe?
AndreB
Andre
Province of Quebec, Canada
2023 F150 Lariat 502a Star White Metallic 157" WB
Samson16
Orlando, FL.
Aviation systems
For start/stop… maybe this;
https://www.autostopeliminator.com/...Rtou2PycNrZNCQI9I-RMPOFoh_kBzk6hoCyc0QAvD_BwE
I installed it on my 2023 lariat 5.0L. Works like a charm.
The PB doesn’t have a start/stop disable button. It is more advanced than traditional start/stop. In normal or eco mode it remains in electric even while driving away from a stop and then transitions to hybrid drive depending on load demand. You also continue to receive cold air from the AC and other niceties that require ICE operation in a non PB truck.
stevemcbo
Steve
2023 F150 FX4 Powerboost
The ICE runs when it needs to and doesn't when it doesn't need to. Simple....
