what is it about the PB tune that you like? acceleration is better, anything else?I’ve had my powerboost tuned from them for the past 2 months,
returned it to stock to go to dealer on Monday. Can’t even begin to believe I used to think a stock powerboost was fast. You can’t even compare these things.
don’t wait on the tune. They change nothing with the hybrid system it works like it was stock. And this truck moves like no other.
can’t say I have “improved milage”my conditions change to much and I only have a 6 mile city drive to work currently.
I’ve used the tow tune and got 1.5ish more in mpg towing comparing to stock, similar weather conditions both traveling from same area pulling the exact same trailer and weight. Only towed once so far hard, haven’t towed any major weight
i
tbh not really much of a different truck other then making 500whp. And shifts smoother shifts 1 2 3 not 1 to 3what is it about the PB tune that you like? acceleration is better, anything else?
Your post may be the one to push me over the line and finally order one! Which tunes did you get? Which one are you running?I got the Powerboost tune for my new (to me) 2021 Lariat. Installed it on Friday and drove it yesterday.
The shifting is significantly better. Much smoother and no gear slipping. And this is even with the transmission “relearning” - Livernois says to suspect the shifting to not be smooth at first.
The power is pretty ridiculous. I haven’t pushed it hard, but immediately experienced the “push you into the seat” power when accelerating on to the freeway and going from 2nd to 3rd. The responsiveness of the throttle is significantly better too. I only drove it in Normal mode andI liked it better than the stock Sport mode.
MPG was 2 MPGs better than pre-tune and I wasn’t trying hard.
All in all - first impression is really good and it appears worth the $
You mentioned taking the time off when you went to the dealer. Any reason why? Is it just frowned on from a warranty perspective?I’ve had my powerboost tuned from them for the past 2 months,
i
Same reason for yzerman, just to reduce chances of them denying warranty if ever needed. Was just an oil change but when tuning it also turns off auto updates so I assumed they would attempt to update my truck while it was in the dealer.You mentioned taking the time off when you went to the dealer. Any reason why? Is it just frowned on from a warranty perspective?
Also how easy is it to remove it then put it back on?
you have to go under the hood to switch between tunes (and for the initial setup). It is pretty easy.Do you have to go under the hood to switch between tunes or just for initial setup and complete removal?
Nice! Hit me up if you have any questions. I found the instructions to be a bit vague but Livernois support was very good when I called.Placed my order tonight. Can’t wait!
