Would this be applicable if we just level the front by 2" and if so, could you be kind enough to point out where we adjust that in FORScan? Thank you!I'd suggest changing the value in the IPMA with forscan regarding your new height and perform a bluecruise alignment. I'm going to play with increasing the truck's IPMA height more in an attempt to get to engage more on roads with narrower lanes.
Without telling the IPMA that the truck is now taller, the system is more inclined to ride lines / become sloppier at holding the lane.
Please elaborate on this value and details of what you are changing, what are the choices, etc.changing the value in the IPMA
IMO and assuming no more than 2" of height change, it is doubtful you need to do anything. If you're going to pay to have anything checked then have your headlight adjustment checked. If you raise the front then you've raised your headlights and are blinding people.I have a 23 Lariat with bluecruise, if I level the truck will it render bluecruise inoperable? Thanks
Link?The instructions for the Ford Performance Bilstein kit (available on their website) shows how to adjust the radar and the headlights post lift. Doesn’t mention cameras or anything else. Might help?
