Leaving truck running while locked.
JimmyB923
Jim
Pennsylvania
2021 Ford F-150
Transportation
Is there an amount of time for my F150 to shut off while locked and still running? I've left the dog in the truck while locked and running w/ the AC on and come out of the restaurant and the truck was not running. Can you set a time limit?
RedTXV
Houston, TX
2021 SQ Limited
I believe it's 30 minutes. A message will pop up and tell you its going to shut off unless you override it.
Pedaldude
Arizona
There must be a Forscan fix for that, police dogs get left in their idling cruisers all the time.
maxinike
Stephane
ontario
f150 powerboost, ranger 2020 and lawn tractor
if you don't want have to turn it on every time use FORSCAN to disable it and the option will be greyed out.
Ajzride
Automation
If you go into Settings/Vehicle the first option on the top is to disable the 30 minute timer. The truck will run until it's out of gas at that point.
To clarify, this resets every key cycle. If you want it to stay off forever you need forscan.
