All the lights off while truck is running?
Vick!
Ron
2022 F-150 XLT
Yes, I have a question. Is there any possible way that I can use my fore scan to turn off all the lights inside of the truck and keep it running?
The second question is, how do I turn off the timer when the truck is running? Why? I ask because if I'm sitting in the car too long, a timer will tell me it's about to turn off. Is there any way that that can be disabled as well?
Big Cam
Nick
North Dakota
2022 Ford F150 Tremor 402a
Support Engineer
I'm pretty sure Yes and absolutely Yes.
You'll need forscan to accomplish both.
Livinitup Forscan thread, check out his Google doc
I know disabling the 30 minute timer is in the common section.
Disable Auto Engine Idle Shutdown of 30 minsIPC720-01-01x*xxxxxxxx--subtract 8 from your default value (if default is F, change to 7)
As for all the lights off, I'm pretty sure it's possible, but you'd be better off asking in that thread. That's where all the Forscan pros hang out.
Edit : I knew I just read it, I just couldn't remember the name. Here is the quote from the Forscan thread.
"Silent Mode toggle in the APIM which keeps the truck dark when you open the doors. That does include the dome lights too but those can still be turned on manually."
