JHForman812
do you have sync 4 with 12" screen? if so just keep the climate IOD up on the right side. I keep it up and music on the left.
yes. It gives you three choices: defrost, feet and straight out into the cab (don't know what they call that one)Can you select both feet and windshield when the icons pop up on the screen?
I don't recall seeing that card. Will check...do you have sync 4 with 12" screen? if so just keep the climate IOD up on the right side. I keep it up and music on the left.
'Freezing' lolI live in the Bay Area so if im ever using climate is usually just blasting cold air, but the last few weeks have been freezing, below 45 degrees so yeah I have found it very easy to use personally
Yes you can, but select more than one and its just 50/50 airflow to each. I know everyone has experienced a time when you just want a little bit of defrost flow to keep the window from fogging and the rest of the heat on your feet. Not possible with the Sync4 in the F150..Can you select both feet and windshield when the icons pop up on the screen?
I’ve noticed more than once that my HVAC set to auto will blow lightly out of the defrost vents, and mostly on my feet. So it seems possible. Whether ford lets you manually select it, idk. I have never manually controlled the climate control in 6000 milesYes you can, but select more than one and its just 50/50 airflow to each. I know everyone has experienced a time when you just want a little bit of defrost flow to keep the window from fogging and the rest of the heat on your feet. Not possible with the Sync4 in the F150..
I guess Ford saved $0.50 per truck putting in open/close dampers instead of continuously adjustable.
THIS:Just give me a physical dial, or a simple button like on the XL or XLT 300A:
