I have a 2021 F-150. I bought the Camburg tubular upper control arms for the 2015-2020 F-150 as well as the king coil overs for 2015-2020. Everything went on with no issues what so ever. Here are a few pics. Also, the ride quality on road is a huge improvement over stock. I highly recommend.Hello!
Do we know if prior year uca will fit? Regardless if he needs them or not.
Falcon front and rear shocks are on the way and I would like to find a set that fits, thanks!!!
Be careful with the sensor mount. Mine broke off at install and I had to weld it back on. I did not bother with a return, simple fix if you have a MIG at home.Rough Country UCAs fit, but there is no provision for the headlight adjustment sensor found on higher trim levels and a custom bracket must be fabricated to retain its functionality.
I'm planning to buy a Bilstein 6112 kit, but it only lifting by 2.5". Is there any point in installing struts with it so that the lift is about 3"? What UCAs would be best then?
