Aron
Weight distribution hitches don't allow for towing heavier hitch loads (despite what trailer salesmen might tell you); they are basically just a huge "wrench" to add a twist (a "moment" in engineering terms) to the tongue to help correct the "V" that would naturally form from adding a huge weight to the rear of the truck.I am a newbie on this topic, but trying to learn from all the folks here myself. You are seeing that you have your wife and yourself weighing in at only 300# right? and nothing for luggage, items in bed, hitch, etc., etc.? Here's mine, and it drastically changes the math from yours...One question for anyone - how does a weight distribution hitch change anything here? or does it? I thought with one I could have a much higher tongue weight?![]()
Without a WDH, putting hundreds of pounds of weight on the rear bumper will force the truck rear to squat and the front to lift (like a seesaw). Without the WDH, this will likely overload the rear axle, while raising the front axle high enough that it may even cause steering issues. The WDH adds a bending force to straighten the truck back out, which has the cumulative effect of "moving" weight from the rear axle to the front truck axle and the trailer axle(s). The weight is still there; it's just being supported by other axles.
Further, the hard limits of the truck hitch point remain--even if you distribute the weight to all axles, you can only stress that hitch point so far. My truck says that it has a max hitch weight of 1400lb with a WDH and 500lb without one (you have to crawl under the truck to see it).
