Fuel door open warning
Mosey
2021 F-150 Powerboost
The past two times I have filled up I received a warning that my fuel door was open when in fact it was closed and locked. In both instances I simply pulled over, shutoff the truck, popped open the door, and then closed it again. The second time was today and I was sure to open the door fully and to close it fully by pushing the door past flush until it bottomed out (not a lot of force).
Anyone seen this before?
turbopilot
Prescott, AZ
2023 F150 Powerboost
In time it won't close at all and you will get an engine light. Well know problem with the PB. Got it fixed under warranty but I always carry this.
Ford F-150 Fuel door open warning billet+fuel+door+pin+megaohm+motorsports
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I have noticed, of I pop open the fuel door right before, or after the truck is turned off, I get the pop-up again after I start the truck. This happens even if I dismissed the notice in the IPC before restarting. I believe you get a different warning other than "fuel door open" if it is actually open and you start driving from the one time that happened to me.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this fuel door concern. Thanks!
CaptSteve
Steve
New Brighton, PA.
2021 Ford F-150 Powerboost Hybrid
Yes, the same issue with my 2021 F-150 Powerboost Hybrid. Alert comes on at start-up and the fuel door open switch does not work.
CaptSteve
Steve
New Brighton, PA.
