Way2qk4u2c
Michael
Austin
2022 F-150 2015 Mustang GT
Network admin
Sorry you are having that error. By no means am I an expert on this or involved in the widget. But, just a couple quick suggestions. Check to see that the widgettool is updated. It should be 2.0. Try removing the widget and re-adding it. If none of that works. Remove the widget, uninstall Scriptable and start from scratch. I have found that sometimes it takes a bit of finesse to get it running properly, but once it does, I haven't had further problems. Hope that helps and be sure to re-read the second sentence of this post.
Yup i removed both the widget tool and the ford widget. I reinstalled the new widget tool and then the ford widget. It works now. I must have a older version of the widget tool. Back in business :)
tonesto7
tonesto7
Anthony
IT Admin | Software Developer
New Release: v2022.02.21.0
I just pushed out a new release which hopefully gets the large widgets working more consistently.
Please let me know the outcome!
shacky4
Sault Sainte Marie, Michigan
2021 Ford Bronco, 2018 Ford Escape
New version loaded up just fine. Smaller buttons on the big version look good! Also, did you do something to make it faster when you tap a button like "start." First impression is it was quicker.
BHunted1
Sumner County TN
Seems to be running fine. ??
trojandawg3
Shannon
Northeast Georgia
2022 F150 XLT Sport 302A FX4 SuperCrew 3.5 EB
Controls & Automation Specialist
Large version seems to be working now! Thanks!
Jaug
Jason
Fargo
2021 F150 Platinum
It is
I deleted it and reinstalled a couple of times and also toggled it on/off I. The iCloud settings.
I checked my Files app and didn’t have a scriptable folder.
Not sure if you got this working or not. I got the iCloud issue for me cleared up by toggling iCloud Drive on and it asked if I wanted to upgrade and I selected to upgrade. After that scriptable worked. Hope this helps.
tardman91
Matt
Odessa, FL
2021 F150 STX
I figured out the iCloud error! You need to have iCloud Drive enabled in the settings. I use it occasionally, and apps have saved data in there, but it wasn’t enabled in the iCloud settings for some reason. Once I toggled it on it worked fine. Thanks for your efforts!
BHunted1
Sumner County TN
Tonesto, is there any way to pull the voltage to tenths/.# ie, 12.5. ?
tonesto7
tonesto7
Anthony
That's a popular question :)
Nope Ford only return in integer form 12, 13, 14 etc no decimals
BHunted1
Sumner County TN
Reason I ask is that the few times I hooked up the charger, the morning voltage was in the low to mid 12.##. Never had a dead battery but I recall ota requires at least 12.5vdc. I monitor connect time as best I can from my xfi gateway connections with separate profiles. The modem may connect 5 or 10mins once in awhile. But nothing ever connects over nite that Ive seen. Maybe this is why otas are not coming in. The mothership pings in, then no ticky washy because of the low vdc. Just a thought.
JediNut
Emmett
Nashville, TN
'21 Ford F-150 Lariat PowerBoost
Old Time Geek
Everything was work great earlier now I get the error message
Is your phone close to capacity? It seems that if it needs to make room for anything, files shared via iCloud are one of the first to go.
When this happened to me... I just cleared a bunch of unused apps on my phone, ran the "FordWidgetTool" script again to update everything and it was all good.
Hope this helps.
Roll.Tide
Rick
Western NC Mountains
2021 F150 King Ranch
Hope this helps.
Thank you, plenty of space, that was not the problem..
trojandawg3
Shannon
Northeast Georgia
Anyone else having trouble getting the latest version to update? It says it updated but it still has an older version running.
tonesto7
tonesto7
Anthony
I’m screwing up!
I forgot to change the version in the file. Run the widget tool to update and you will be good.
