Ford procal 4 tuned issue
Blackbetty406
Kent
Missoula
2023 ford f150
Airfield operations
My truck 2023 f150 3.5 eco, tuned with the ford procal and went to use forscan and no connection (it wants the program code which i entered, still says contact forscan)
second issue was figuring i could return to stock but no such luck, procal says ecu read not write available.
Am I looking at frds and programming pcm back to oem?
If you're not making PCM changes, just feed it
NL3A-14C204-DCJ
Blackbetty406
Blackbetty406
Kent
Missoula
2023 ford f150
Airfield operations
Ok ill give that a shot thank you
Blackbetty406
Blackbetty406
Kent
Missoula
2023 ford f150
Airfield operations
Spaced what i was doing, actually wanted to disable active air dam (just ghost codes now) nothing on screen but have a tremor skid plate coming
