Ford Performance Raptor Steering Wheel Upgrade Kit
missileboy
MD
24 F150
Just did this to my 2024 XL 5.0 this weekend-
Mine is a column shifter. Bought the Raptor wheel from FORD Perf for ~650 bucks. It has the red stripe and is configured for heat.
Bought the Boosted Grey Goose wiring harness as the XL's DO NOT COME WITH THE WIRES ALREADY INSTALLED TO SUPPORT THE PADDLES, that must be on higher option level.
Removed neg cable and then removed air bag. Once the airbag is out, use a T50 and remove the wheel. Be careful not to spin the clock spring too much and lose orientation. Now that your stock wheel is off proceed to bezel swap between the two wheels.
YOU MUST SWAP YOUR XL BUTTON/TRIM bezel piece to the Raptor wheel if you want your steering wheel controls to work! It is pretty easy to swap them. remove the two screws, unplug the horn connector (red) from its holder and unplug the two connectors to the button modules on the left/right side of your trim piece and SLOWLY pry it up and out. On the bottom of the wheel there are 3 plastic nipples on the under side of the trim piece that you slowly pry up and out. No glue, just a tight press fit. I used an interior trim removal tool and very slowly just went around the perimeter of the trim bezel and pried it up and out. Did the same to the Raptor wheel and then installed my XL trim piece and plugged the button modules back in and put the 2 screws in. No glue, just a press fit, and it looks awesome.
XL's WILL NOT SUPPORT HEATED WHEEL. You would need to buy a harness adapter to make the wheel have heat. There is the plug on the bottom of the clock spring for the heated wheel plug that comes with the raptor wheel, but it DOES NOT HAVE ANY CONNECTIONS to it, just a blank female plug/place to put the male plug from the wheel so it stays out of the way. Assume higher level trim would have that plug wired to have heat, not on the XL.
Removed the glove box (EASY no tools) and hooked up the plug in line to the C210 connector (Big GREY one in the middle of the plugs behind the glove box). Then I used a long/heavy duty Zip tie and was able to feed it behind the HVAC and it came out under/to the right of the steering wheel. I taped the 3 wires to the end of the zip tie on the glove box side and used it to pull the wires through. I DID NOT HAVE TO REMOVE ANY TRIM OR OTHER PANELS TO GET THE WIRES ACROSS BEHIND THE HVAC AND OUT UNDER THE STEERING WHEEL. It did take a few tried to get it to fish through and come out under the steering wheel.
Once I pulled the wires through, I then removed the top piece of steering wheel stock cover and the lower piece and exposed the C218A plug on the right side of the steering stock by where the shifter mounts. Remove theC218A plug, slip the wire retainer clip up on the C218A plug and pop in the 3 wires to the 3 empty spots on that plug (5/6/7 on C218A on the 21-24's) and then put the covers back on and done. The wires are labeled as is the plug so make sure you insert the correct wire to the correct slot.
After the harness is installed, put the new wheel on, connect up all of the plugs and re-install the air bag. Connect up your neg cable/power and go-
When you look at the instruction BGG sends you, there are some pictures in the instructions for console shifter models and some for the steering collum shifter, so don't be confused. They tried to use one set of instructions for both collum and center console shifters and it could be confusing to some. They show you removing a lot more trim pieces that I didn't need to remove once I got the idea to use the long zip tie to fish it through behind the HVAC. I assume for the floor shifter models; you would need to remove more trim to get the C210 plug than on the collum shifter models possibly?
Feels so much better than the stock rubber POS! And now I have paddles that work-
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
I haven't seen this come up myself, but there is a kit I stumbled onto that's listed as "OEM Raptor Steering Wheel Upgrade for 2021+ F-150." Last I saw the new wheels were about $900, and used ones weren't much cheaper.
$630
https://accessories.ford.com/2021-f-150-raptor-steering-wheel-kit-black-m3600f15b/
https://performanceparts.ford.com/part/M-3600-F15B
Says it includes all wiring, but there is a wire needed to be added on the steering column side for the paddle control, isn't there?
Levittown also has it for $496.44: https://www.levittownfordparts.com/sku/m-3600-f15b.html
The instructions call out M-3600-F15C and that they are for a heated wheel, so maybe another version coming?
Is this old news?
I read the instructions....it does not indicate an extra wire..
missileboy
MD
24 F150
Update to 2024 XL install of the Raptor Wheel with heat-
If you are using the Boosted Grey Goose (BGG) wiring harness on a 2024 XL (what my truck is, might be the same for other trims, I don't know)
Ford changed the pin out some on the 24's and with the BGG wiring harness, while my paddle shifters worked after install, my horn didn't! I went back over and unplugged the C210 connector behind the glove box and hooked it back up stock, and the horn works fine! Sent BGG an email and literally within 20 min they had responded and apologized, they are sending me 1 wire I have to add to the 2 plugs on their C210 connector/harness and that will make the horn worked as it should.
If you have a 24 and want to use the BGG harness, talk to them first. I am sure they will eventually make a 24 specific harness as it is slightly different (horn pin out) than the 21-23's. I just checked their website and they are sold out of the harness' for now and still only show them for being for 21-23 models .
Syclone Rob
Rob
London Ontario Canada
2023 F150 5.0L Screw 3.73 BAP
Thank you for the info. Just to confirm, the part number for the wheel you bought was M-3600-F15B?
Mxkx36
Jimmy
Arkansas
2023 f150
Transportation
Just did this mod last week bought my wheel from summit racing used wires from left over taillight project they pinnned right in and just jumped to the shifter wires​
Ford F-150 Ford Performance Raptor Steering Wheel Upgrade Kit IMG_6106
Ford F-150 Ford Performance Raptor Steering Wheel Upgrade Kit IMG_6341
OIF_Veteran04
Joseph
2023 F150 Regular Cab XLT
They're the same sans the insert. Just use your insert or paint / mod to your desire.
They are not the same. The stitching is red and the ugly orange strip isn't on this one.
oookay, well my heated red stripe black stitching wheel disagrees with ya. It's almost as if there's red, orange, and blue variations of the wheel. Beats me ?‍♂
OIF_Veteran04
Joseph
I haven't seen the red or blue version anywhere. Only the orange.
If you have a different version why not share where you got it or the part number?
Didn't mean to be rude or anything.
Tilstad
KJ
Tx
2025 F150 RCSB
What is the size difference between this and stock?
OIF_Veteran04
Joseph
The part number for the Raptor R steering wheel is: RL3Z-3600-PA
VIN: 1FTFW1RJ2RFA46174
This is a picture of it.
Ford F-150 Ford Performance Raptor Steering Wheel Upgrade Kit 16805b0cdb2844a292bf415799054726
