R8er
Hi, just replaced the oem battery with an everstart H8 AGM. I went to reset the BMS, but there is no battery light on the dash. I went ahead and tried the five/3 reset procedure, but it doesn't do anything.
Also get, check brake system warning when turning on ignition along with battery state of charge low message. Then the BRAKE light stays on even after making sure parking brake is not set.
Checked brake fuses under hood, 28 and 29, both look good. Are there any other fuses?
Battery voltage shows 12.3 in forscan. I made sure battery was charged all the way before installing.
current DTC:
Code: U3003 - Battery Voltage
Additional Fault Symptom
16):
- Circuit Voltage Below Threshold
Status (-AB):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 104889815 s (Sun Feb 02 16:19:26 2025) - Event time
-TOTAL_DISTANCE: 45532 km - Total Distance
-MODULE_VOLTAGE: 14.3 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 10 °C - Outside temperature
-PWR_MODE_KEY: Running (Position 2) - Power Mode Key State
-ECU_POWER_SUPPLY: 14.1 V - ECU Power Supply Voltage
-ECU_F_RSC: Inactive - ECU System Flags - Roll Stability Control
-ECU_F_ABS: Inactive - ECU System Flags - ABS
-ECU_F_BTCS: Inactive - ECU System Flags - Brake Traction Control System
-ECU_F_TCS: Inactive - ECU System Flags - Traction Control System
-ECU_F_AYC: Inactive - ECU System Flags - Active Yaw Control
-ECU_F_HDC: Disabled - ECU System Flags - Hill Decent Control
-ECU_F_ESC: Inactive - ECU System Flags - Engine Drag Control
-ECU_F_TSC: Inactive - ECU System Flags - Trailer Stability Control
-TCS: INACTIVE - Traction control system
-EDC#1: INACTIVE - Engine Drag Control
-BTCS: INACTIVE - Brake Traction Control System
-AYC: INACTIVE - Active Yaw Control
-ABS: INACTIVE - Antilock braking system
-BFLHP: 0.0 kPa - Brake Fluid Line Hydraulic Pressure
-BRK_F_P_R: 0.0 kPa - Brake Fluid Line Hydraulic Pressure (Raw Value)
-IFC_D703: 121 - Internal Module Fail Code
Any help is appreciated. any fuses to check etc... anything else?
Thanks in advance!
current DTC:
Status (-AB):
Freeze Frame #1:
Thanks in advance!
