First time being stranded
Pedaldude
Arizona
I have a question about your battery monitor. Do you leave it plugged in all the time or only when you get in and start the truck? If you leave it plugged in all the time, is there any battery drain associated with it? Thanks
Can’t help with your question. I don’t even leave loose change visible in my truck, I don’t need any reasons for some homeless crackhead to smash my windows.
I leave it in the glovebox and use it when I remember to, or if I haven’t started the truck in a while. The key time to check is when cranking the engine.
Good luck!
My 2ND Ford
Ny
Good luck!
You told me enough to answer my question, Thank you.
