texski
- First Name
- Mike
- Joined
- Feb 4, 2022
- Threads
- 5
- Messages
- 113
- Reaction score
- 79
- Location
- Arlington, TX
- Vehicles
- 2022 King Ranch Super Crew, 1997 Lariat Super Cab
- Occupation
- Retired
I use Pennzoil Platinum, not Ultra. I use the Wix XP filters (XP are for synthetics). First change was at 300, then 1,000, and on the 5's there after. My latest Blackstone at 30k looks great. Wear metals are low compared to universal averages for the Ford 5.0L, and the other properties are well below in expected values.
If you want to do a deep dive into oil and lubrication, check out Lake Speed, Jr (the Oil Geek Guy) on YouTube. He is a Tribologist and Certified Lubrication Specialist, and has formulated many oils for the major brands, and his break in formulation is used by prominent engine manufacturers (not engine builders). His resume is exhaustive.
Here is his analysis of
Pennnzoil Platinum vs Ultra
And for a video on Oil Change Intervals, Dave's Auto Center (Monster Engines.com) had Lake out for an onsite visit. The knowledge and experience these guys have about engines is staggering. Well worth the 30 minute view. And for all those that preach 10k intervals, this should change your mind.
The truth about oil change intervals and analysis
The simple fact is that most oil companies buy the same base oil, and they add ... additives, to combat wear and deposits. Changing your oil frequently, <5k for normally aspirated, should be sufficient maintenance for your engine. Many would say frequency is more important than brand name. Adding additives will dilute the oil's formula and found to be detrimental.
If You LOVE One Of These Additives, DON'T Watch This Video!
Good luck!
Good luck!
