Fibre Glass Beds?
fmdog44
steve
2012 F150 XL
Saw a video of a wreck this morning on the local news involving a very late model F150 and the bed appeared to be 100% fiberglass. I never knew that to be the case. I can't believe any maker would do that.
tbinmd
22 KR F150
The outer shell was fiber glass and the inner liner of the bed was steel. Fiberglass was for the fender flares. Same thing on a F350 dually.
Pedaldude
Arizona
Depending on the end use, fiberglass, or some sort of composite isn’t that much worse than aluminum alloy or steel as a bed material.
I am sure many were upset when wood beds (a sort of composite) were replaced by steel!
  • Like
Reactions: 780
Todd
edmonton
Yep. Pretty sure new Tacoma's and Tundra's have composite beds.
SRHAGEN
S
RICHMOND ky
2016 F150 XL SPRCAB Sport 4x4 V8 3.73 36 gl tank.
DOD USAF test track ARMY RETIRED PMEL/TMDE
Yep to the yotas being plastic. Claims it’s stronger and more durable. No dents.
Kodiak
I have had a 2009 Tacoma with a composite bed since I bought the truck new (ordered it). I did not really like it at first but over the years I have really put it through its paces and it has held up remarkably. It does kind of look like a drop in bed liner but what it lacked in visual appearance it made up for with functionality.
Zengineer
Midwest
2022 Lariat 157wb
Tacoma has been compression molded fiberglass reinforced plastic (composite) for the past 18 years. New Tundra uses a similar fiberglass reinforced plastic (composite) today.
Same was true for the Sport Trac and some of the Ridgeline.
The GMC optional Carbon-Pro box is carbon fiber reinforced...very expensive solution.
  • Like
Reactions: 780
Zengineer
Midwest
2022 Lariat 157wb
No idea what you were seeing....maybe a drop in liner or reinforced spray-in. The F150 floor and inner walls are aluminum.
Regardless...keep in mind that 100% fiberglass would just be a pile of strings or fibers that are about as strong as a pile of grass clippings. People talk about boats and Corvette body panels being "fiberglass". They are really fiberglass reinforced composites. The glass might be chopped, strands or woven mat....but it is just the reinforcement in the mix of fiber, resin, fillers and other additives for color or fire resistance, etc.
fmdog44
steve
2012 F150 XL
I know what damaged fiberglass looks like and it was fiberglass. It was a side view only not a top view. Bottom line is I was not aware any portion of the beds (sides) were anything other than a metal of some sort. I don't like the idea simply because of the huge difference in repairing a dent versus replacing the part regardless of the weight factor.
Zengineer
Midwest
2022 Lariat 157wb
I would like to see that picture. I can only guess it was a liner, toolbox, tonneau, topper, one of the underbody shields (some are fiberglass reinforced), part of another vehicle, or something other than the bed floor, bed walls or exterior bodysides.
I am not just guessing about the bed structure. I've been involved in automotive composites for over 35 years including many Ford vehicles. The Lightning has a composite floor/ tub/liner in the FRUNK but I'll assume you know the front from the back.
hotrodmex
Ca
22 Lariat 500.5a
From a 2018
Ford F-150 Fibre Glass Beds? 1654707615961
That would be some crazy strong/flexible fiberglass.
fmdog44
steve
2012 F150 XL
I would like to see that picture. I can o ly guess it was a liner, toolbox, tonneau, topper or something other than the bed floor, bed walls or exterior bodysides.
I am not just guessing about the bed structure. Ive been involved in automotive composites for over 35 years including many Ford vehicles. The Lightning has a composite floor/ tub/liner in the FRUNK but I'll assume you know the front from the back.
You guess wrong. It was the entire bed side exterior, not the floor like T-boned. No pic as it was on TV.
Pedaldude
Arizona
Many aftermarket body panels are fiberglass, especially the ones with huge flares. Some of them look almost OEM, especially when they have a good paint job or available stock graphics stickers:
https://www.mcneilracinginc.com/pro...raptor-2-off-road-fiberglass-bedsides-5-5-bed
Often on a quality fiberglass panel, an impact that would dent a steel or especially aluminum panel won’t even scratch the gelcoat let alone damage the panel. If the impact is enough to destroy the fiberglass panel, it likely will destroy the metal panel beyond repair as well.
When Pontiac started making urethane bumpers, they had to do an entire ad campaign to dissuade any fears about a plastic bumper:
