F150 Cluster Upgrade Re-Calibrate
colbysturner
Colby
Utah
2021 F150 XLT
I recently installed a 12” gauge cluster screen in my F150. I previously had the 8” screen with the normal RPM / MPH gauges. However I need the screen calibrated so the fuel displays correctly, the Mileage, and Drive modes. Can dealers preform this calibration? Thanks!
Dealer can't help with non-OEM mods.
You might be able to find some old posts if you search across the internet.
If you have FDRS it might be able to program for you. Haven't done it personally as the 12" doesn't buy any additional functionality. Look through the similar threads showing up below this post.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Informat.com offer that upgrade. They may be able to help re calibration.
Rubalcavo03
Kevin
California
2023 Ford F150 SCSB
Low Voltage
I recently did the 8’ to 12’ Cluster from @LACOLORADATRUCKPARTS And he programmed my cluster all that good stuff what do you mean calibrated? Like your cluster didn’t get programmed correctly ? Or why are you saying it needs to be calibrated
